kia optima k5 - 2.0 ile ilgili bir kaç soru
'Optima Forum - Club' forumunda Khenn tarafından 12 Kasım 2015 tarihinde açılan konu
  1. ism@il
    The Optima features a 2.4-litre four-cylinder direct-injected petrol engine that generates 148kW @ 6,300rpm and 250Nm @ 4,250rpm – one of the most competitive naturally aspirated four-cylinders in its class.
    Khenn bunu beğendi.
    The 274-hp, 2.0-liter turbo four with 269 lb-ft of torque is silky smooth and punches hard enough to send the 3500-pound Optima to 60 mph in 6.4 seconds and through the quarter in 15 flat.
    Khenn bunu beğendi.
    optima 2.0 165 psi
    Pop the hood on the Nu Optima and y0u’ll discover a new engine cover with the alphabet CVVL which stands for Continuous Variable Valve Lift. The CVVL system controls both air intake and exhaust to optimize performance, emission and, like everything else, improved fuel economy. No official catalog has been released on its improvements over the Theta II but what we can see is that the Nu has a rated PS of 165 @ 6,200rpm with 198Nm of torque at 4,600rpm which is exactly the same as its predecessor and it’s paired to the same 6-speed automatic gearbox (Note: International reports indicate that rated power has improved to 170 or 172PS with 3Nm increase to 201. Until the official release from NazaKia, I am inclined to report what little evidence I have now). The difference comes in its lighter weight which translates to about 3-5% improvement on fuel economy.
    Khenn bunu beğendi.
  4. Khenn
    Khenn Acemi Sürücü
    11 Kasım 2015
    eskişehir
    Mahmut YErli
    kia k5
    hocam benim motor işte bu aynısı. fakat ruhsatta 2.0 127 kw yazmaktadır. haa vergiden kaçınmak için ufak yazılmış olabilir. doğrudur. fakat araç gaz a dokundugum anda kafamı geri atıyor boynumu kıracak derecede.
    ama bu degil motor eminim.
    bu hiç değil hocam.. yarın temiz bir resim çekip koyacağım foruma motorun. o zaman daha emin olursunuuz. ama dediğim gibi ilk yanıta aldığımdaki motor eminim.
    ism@il bunu beğendi.
  5. ism@il
    Hayırlısı olsun. Arabanında resimlerini bekliyoruz. Güle Güle kullanın
    Khenn bunu beğendi.
  6. Khenn
    Khenn Acemi Sürücü
    11 Kasım 2015
    eskişehir
    Mahmut YErli
    kia k5
    teşekkürler. gerçekten ama hala motorda kafam karışık yarın emin olacağız inşallah
  7. Khenn
    Khenn Acemi Sürücü
    11 Kasım 2015
    eskişehir
    Mahmut YErli
    kia k5
    evet arkadaşlar bugün itibariyle bir genel temizlik yapayım dedim. ve motor kapağını söktüğümde karşılaştığım şey olayı çözmüş bulunmaktadır.
    motor kapağının altında iç kısmında 2.4 gdi yazmakta olduğunu gördüm. üstüne yazılması gereken yazıyı içine yazmışlar.
    sanırım bununla beraber kafamdaki ve kafanızdaki bütün şaibeler ve sorular açığa kavuşuyor sanırım. 2.4 gdi motora sahip araç. ve beygirini öğrenme vakti. sanırım bi arkadaş yazmıştı yukarki yazılarda bi bakınıyım onlara
    edit : evet motor bu ..
  8. ism@il
    İyi olmuş.
    Dediğim gibi çıktı demek.
    Müsait bir zamanda fotoları da bekliyoruz. Güle güle kullanın
    Khenn bunu beğendi.
  9. Khenn
    Khenn Acemi Sürücü
    11 Kasım 2015
    eskişehir
    Mahmut YErli
    kia k5
    teşekkürler ismail bey. yakın zamanda çekeceğim bol bol resimler. telefonum arızalı olduğundan kameralı telefon mevcut olmadığı için çekemedim.
    ve sanırım sormama gerek yok bendeki k5 den tr de pek yok sanırım göremedim karşılaştırma yapabileceğim konular mevcuttu.
  10. KAPSHY
    Abbo kapağın altından canavar çıkmış [emoji85] ne gidiyodur o be [emoji23] tekrar hayırlı olsun soruların netleşmesine sevindim [emoji3]
    Khenn bunu beğendi.
  11. Khenn
    Khenn Acemi Sürücü
    11 Kasım 2015
    eskişehir
    Mahmut YErli
    kia k5
    çok sağol gerçekten canavar çıktı çok fena gidiyor. artı boğulma vardı.. benzin değiştirdim 97 aldım. boğulma gitti. 97 oktav benzinde yakındaki bir shell de buldum o yöndende kafam rahat.. başka bir sıkıntısı yok şimdilik incelemeye ve öğrenmeye devam ediyorum. bi tek hız sabitleme takma peşindeyim. mümkünde beşiktaş ta servise gidip görüşeceğim.
    sezops ve KAPSHY bunu beğendi.
  12. sezops
    sezops Usta Sürücü
    23 Haziran 2013
    eskisehir
    Murat Gündaş
    XD2
    Aracın tüketimi ne durumda acaba?
  13. Khenn
    Khenn Acemi Sürücü
    11 Kasım 2015
    eskişehir
    Mahmut YErli
    kia k5
    aracın tüketimi çok değil. aslında ilk başta korkularım vardı, baya yakar diye. ama endişemin yersiz olduğunu kullanmaya başlayınca fark ettim. şehir içi 45 uzun yol 30 la 33 kuruş arası değişiyor. hız sabitleme olmadığından uzun yolda bence çok yakıyor. hız sabitleme taktırır'sam şayet, azbi mecra da olsa düşer diye düşünüyorum.
    sezops ve D3hs3tt bunu beğendi.
  14. D3hs3tt
    D3hs3tt Ralli Pilotu
    19 Eylül 2013
    Yalova
    Ethem Kösem
    Yakıt bence süper 2.4 cc motor dan bahsediliyor.resmen büyülendim sürüş zewkini düşünemiyorum bile bol bol keyifli sürüşler dilerim..
  15. freedom1259
    freedom1259 Sürücü
    28 Ekim 2014
    emin tunel
    Maşallah o motor hacmine o yakıt hiç bir şey değil . hocam bir an önce resimleri bekliyoruz
    Discovery cihazımdan Tapatalk 2 ile gönderildi
    Evet fotoları bekliyoruz.Optiması olan ilk üyemiz sizsiniz.:)
  17. Khenn
    Khenn Acemi Sürücü
    11 Kasım 2015
    eskişehir
    Mahmut YErli
    kia k5
    sürüş keyfi emin olun bir m3 veya mercedes cla 200 keyfi. virajlarda sallama yan yatma gibi korku olmadan. artı olarak 200 230 arası km hızında sanki 110 120 ile gidiyormuş hissi veren bir araç. ayrıyeten dışardan gelen ses 0 desibel neredeyse camlar açıkken verilen sesi. camlar kapattıgımda surat 130 bu arada nerdeyse kısık sesle yanımdakiyle dialog kurabiliyorum. çekiş gücünden bahsetmiyorum bile. gazı köklemediğiniz sürece. motor sesi duymuyorsunuz hızlanmada veya yokuşta. çünkü güçlü tork bunu sağlıyor.
    en yakın zamanda fotoları atacağım. optima olan ilk üyeyim ve baya bir araştırdım 2.4 gdi motorlu optima da ilk sanırım türkiyede.
  18. pascalim
    pascalim Ralli Pilotu
    4 Nisan 2011
    Orhan İLYASLI
    Ceed Consept Plus SW
    Maşallah sevindim bende.
    Kazasız belasız kullanın inşallah
  19. ReNe
    İsmail biraderim süper buldun 2.4 litre motoru ;)
  20. Khenn
    Khenn Acemi Sürücü
    11 Kasım 2015
    eskişehir
    Mahmut YErli
    kia k5
    beyler yalnız bir sıkıntı fark ettim bugün umarım anlarsınız bundan da .. aracın kliması ısıtmıyor. aldığım kişi klima yok dedi ama azda olsa ısıtıyor çok canı gönülden bir ısıtma yok. diğer araçlardan bildiğim kadarıyla bir klima böyle olmamalı. nedeni nedir sizce acaba ?
